88 IROC Two Fan Problem
Old Dec 12, 2004 | 09:17 PM
RyanZ48's Avatar
Car: 1988 Camaro Iroc-Z
Engine: 305 Tuned Port
Transmission: 700R
I've had my 88 IROC (305 Tuned Port) fans hooked up in the fuse panel but would like to have them hooked up as they were originally. Below both relays is some sort of wiring harness that goes from the relays and to the fans. It consists of approximately 5 or six wires and is some sort of a "plug-like" thing. The wires have been cut and I have no idea as to how they should be rewired. Can anyone be of any help? Possibly with a picture of a similiar harness?
I appreciate any advice!
Thanks,
Ryan
RyanZ48@aol.com
Old Dec 12, 2004 | 10:24 PM
Bill Speed's Avatar
Car: 1989 Formy droptop/88 Deville
Engine: L98 350 TPI
Transmission: factory RWD, WS6 susp
I have an 89 L98 350 TPI,the radiator holds no fluid now...bad side tank. My Chilton manual details I may have to remove the fan, but I figured pulling it away would be enough to remove and replace (r/r) the old with new and reconnect. My main holdback is horrible Midwest arctic winter blast and no garage! I also have a few bent cooling fins on the replacement radiator I'm currently dealing with. I have an odd piece on the new Modine Radiator from an 88 Camaro that I think was added...maybe making new pics to show that off as I'm not aware of it's use
BILL
Old Dec 16, 2004 | 03:44 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: 88 IROC Two Fan Problem
Thanks,
Ryan
RyanZ48@aol.com
Sent you an e-mail
Fronzizzle
Aug 17, 2015 02:52 PM
TA8487
Aug 16, 2015 12:21 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
Leggman1
Aug 6, 2015 04:15 AM
