Fan switch with ECM turn on
Old Dec 19, 2004 | 07:39 PM
DustyJL's Avatar
Car: 91 Camaro RS
Engine: 3.1L V6
Axle/Gears: Stock 3.23 open diff
I want to install a switch but i also want the ecm to turn on the fan when needed. How would I wire this setup?
Old Dec 20, 2004 | 05:30 PM
Nitsuj86Iroc's Avatar
Car: 86 Camaro Iroc-Z
Engine: 305ci TPI
There is something exactly like what you want. Look in the technical articles on this site, and in the cooling section there are 2 pdf files, one for single fan and one for double fan. check it out.
Willie wrote it, you can let ur fan temp be adjustable, or switch back to the stock setting. not too complicated either
RazorN8
Jan 7, 2022 11:44 AM
86IROC112
Aug 17, 2015 02:00 PM
TA8487
Aug 16, 2015 12:21 PM
ZsTransAm
Aug 11, 2015 07:30 PM
Fronzizzle
Aug 9, 2015 01:15 PM
