Water Pump Removal? - 4 belt system...
Old Dec 27, 2004 | 05:54 PM
GTAlover's Avatar
Car: 1986 Camaro
Axle/Gears: 4.10
I'm in the process of replacing the water pump. I got one side clear, but I can't figure out the other side. It looks like I need to remove the power steering pulley and the power steering pump. DO I NEED TO REMOVE THE POWER STEERING PULLEY??? I used to have a GTA with serpetine setup and didn't remember it being this hard....this 4 belt crap sucks! Here is a pic of why I think I need to remove the power steering pump or atleast the bracket. I can't get at this last bolt holding the pump in and I won't be able to install the water pump correctly without this power steering bracket out of the way.
Old Dec 27, 2004 | 08:21 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
you don't need to remover the pulley from the pump. there is another bolt toward the top of the pump bracket you need to remove & a nut on the back side of of the pump to remove which is the hardest 1 to get off, the power streeing pump bracket may also be attached to the exhaust manifold bolts. once you have all the bolts & nuts out, you cam lay the pump assembly to the side, you may need to tie it up to keep it out of the way.
Old Dec 27, 2004 | 08:57 PM
GTAlover's Avatar
Car: 1986 Camaro
Axle/Gears: 4.10
Thank you very much for the helpful information. I was stuck on the one nut way way in the back. I can't believe how many nuts and bolt are on those brackets!!! Once I got that nut off you were right just move it to the side. I'll finish up the install tomorrow after I make a trip to the parts store for some little things to help me put the new pump on. Thank you.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
