Lower Thermostat ECU Problems?
Old Dec 31, 2004 | 07:17 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Ive heard that with lower temp thermos, computer problems can arise.What kind of problems and how can they be fixed?
Old Dec 31, 2004 | 10:33 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
at a specific temperature threshold (155 on my LO3, for instance), the TCC will no longer lock. This *can* lead to transmission overheating and failure. Other concerns include the same minimum-temperature criteria for closed loop operation, which will severely degrade fuel economy. As long as you don't go with a thermostat under 170 degrees, you should be fine. (Recently had to ditch my 160 because it was overcooling in winter and dipping below 155 on the highway)
Old Dec 31, 2004 | 11:54 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Don't forget the CTS.
Old Jan 2, 2005 | 11:39 AM
TechSmurf's Avatar
Engine: LS1, Scrap
Mmmm... no.... nothing CTS related.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
nuggie
Aug 25, 2015 01:27 PM
