Where can I get radiator mounts like these?
Old Jan 11, 2005 | 01:05 PM
fbody83's Avatar
Car: 1983 firebird S/E
Engine: Built 350
These seem simple and would work fine with my griffin. Where would I find radiator mounts similiar to these?
Attached Thumbnails Where can I get radiator mounts like these?-picture-102pike.jpg
Old Jan 11, 2005 | 01:14 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
If you look in the junkyard you will find them on older cars
Old Jan 20, 2005 | 05:50 PM
BOTTLEDZ28's Avatar
Transmission: A4
Id say just make a set out of brushed aluminum. They will look much better then those tiny little things. If you make brackets be sure to allow space to put a piece of rubber for the vibration.
Old Feb 10, 2005 | 10:34 PM
[VU]Juan's Avatar
Car: 84 TransAM
Engine: Chevy 355
Transmission: TH350
I made my own, used a dremel, 4 bolts, and 2 dollars worth of sheet metal from homedepot, looks good, took 15 minutes to make, and holds like a champ...
Old Feb 15, 2005 | 02:16 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Is that two turbos I see with intake filters? Superchargers?
Old Feb 15, 2005 | 05:26 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Looks like old Ford stuff.
Old Feb 15, 2005 | 08:24 PM
fbody83's Avatar
Engine: Built 350
Yeah its an old Mach 1 being made into a twin turbo
Old Feb 17, 2005 | 12:31 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Early 90's Toyota Corolla's have them too, worked well for me.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Bohemian
Aug 15, 2017 05:11 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
