82 t/a LG4, auto trans, a/c, mechanical fan, copper or alum ?
Old Jan 11, 2005 | 01:40 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
what were they in 82 with LG4 and mechanical fan and auto trans and a/c ? were they aluminum or copper ?
does anyone know
for sure ??
what was put in them factory ?
help!
thanks
Old Jan 11, 2005 | 08:46 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
Old Jan 16, 2005 | 04:02 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
It would be the same as my '84 LG4. Engine driven clutch fan with a aluminum radiator core and plastic side tanks.
Old Jan 16, 2005 | 08:28 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Ditto
Old Jan 17, 2005 | 11:46 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
ok
so no copper ones were used 82 92 ?
i had an 84 that was copper rad
was it not factory ?
i really think no one on this forum has any idea what rads were used in what
for real
thanks anyways
Old Jan 17, 2005 | 04:14 PM
Dens71TA's Avatar
Everything '82 on was aluminum core with o-ringed plastic side tanks. The 1980's was about that time GM started switching to that style in all their vehicles.
Copper core radiator sounds like it was aftermarket or somebody cobbled one in from an older car that fit. The factory radiators were made by Harrison.
Old Apr 21, 2005 | 10:02 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
so was just an f body thing then eh ?
cuz all 80s RWD ive ever seen been copper
but them im used to the a and b bodies,
the g bodies im pretty sure are copper brass also but they are 27" wide same as third gen f bodies i know
cant put one in place of a third gen f body 17" alum radiator ?
hmm
hope someone knows ? someone here surely must be a guru on this subject ?
thanks
Old Jul 7, 2005 | 01:10 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
dens and paul; do you guys have pics of your setups ? or anyone else with 82-85 stock factory mechanical fan and shroud setup for these cars ?
thanks
i really need to see what the fan looks like and how they mount up with or without spacer, etc.
need details SUPER BADLY
seems like no one has any idea how the fans bolt to the waterpump hubs ?
how many grooves on water pump pulley for with a/c and p/s ?
any original GM stamping part numbers ? numbers from halves of fan shroud ?
length of fan mounting bolts ?
measurements, fan diameter ? hole in shroud diameter ?
distances from fan to radiator and fan to engine block ?
thanks
Old Jul 7, 2005 | 02:35 PM
paul_huryk's Avatar
I have no pics at all of my motor with a mechanical fan - it hit the junk heap in 1991 - I have the dual L98 electric setup now. I would never go back to the mechanical fans in a thirdgen....
Old Jul 7, 2005 | 03:03 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
but what else could i do in this 82 LG4 T/a then ?
im at a loss if i shouldnt go to mechanical like factory put in it
just be more other parts that i cant damned find for this car, and wiring to do then.. and so forth
hmmm
ideas, recommendations ?
thanks
RazorN8
Jan 7, 2022 11:44 AM
BlueIroc-Z
Jun 9, 2019 03:22 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Leggman1
Aug 6, 2015 04:15 AM
