i melted my relay plug help
Old Feb 13, 2005 | 01:12 AM
justin86z's Avatar
Car: 86 z-28
i melted my eltc fan motor relay plug by the battery whats the best way to wire it with out it 86 z-28 tpi
Old Feb 15, 2005 | 05:38 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
I did the same thing on mine. I was able to get one from GM for $15 I believe it was the same as the MAF power relay (can't be 100% tho) They had a book I matched up the picture. If no luck there, maybe a junkyard if you can find a good one. Last resort spade connectors Solidered not crimped, with insulation covering the outside of the spade (so they don't touch together).
P.S Bosch makes a 30A relay kit with a connector included. Like $8.00 at an import parts store here in AZ. Just another thought.
Old Feb 19, 2005 | 03:04 PM
rudyt5000's Avatar
Car: 87-Z r.i.p & 93-Z sold 99s-10
Engine: 305 TPI , 350 LT1, 2.2 4cylinder
Transmission: 700 R4, 4l60, ?
just replace it with another relay....instead of wiring it without it and then having more problems ....my fan relay was like only 3 or 4 bucks and was so worth it
Old Feb 27, 2005 | 10:08 AM
FactoryFreak's Avatar
Car: 1988 GTA
Transmission: TH350
You might want to check he wiring under the relay box, it may have a decayed wiring therefore causing the high amps that melted your relay
Old Feb 27, 2005 | 11:26 AM
Vader's Avatar
Standard Motor Products jas a nearly complete line of electrical connectors, sockets, and plugs for almost every domestic model vehicle. They have some of the most obscure, one-off connectors you might ever see. Try finding the connector for the optional lighted rear heater switch on an old Safari van somewhere else.
GM also has a catalog of Delphi and Yazaki connectors used on their vehicles, and may be able to identify the socket.
Of course, you probably won't find these at any of the common chain stores that sell oil, blue headlights, and stickers. You'll have to go to a real auto parts store. And don't worry about that squealing noise you hear in the background in lieu of fourteen stereos playing different hip-hop stations. It's probably only a boring bar in their machine shop or somthing else indicating that REAL work is being done there. You'll get used to it.
Old Feb 28, 2005 | 02:48 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Sigh I love those places
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Gunsbee
Sep 7, 2015 07:10 PM
Glowsock
Sep 6, 2015 06:40 AM
