how many connections on the heater fan?
Old Feb 14, 2005 | 09:08 PM
91blue_fire's Avatar
Car: 1985 iroc-z
Engine: 305 tpi with hooker super comp exhaust
Transmission: stock 700r4
my heaterfan turns off and on. sometimes its fine other times it isnt on...i hit a bump..its fine! ive had problems with a heater core leaking..is that part of the problem? i am replacing it, dont worry..just wondering if the fan has something to do with it. today i got out when it wasnt working and i tapped on the cylinder looking thing (yeah..where the fan is) in the top corner of the car...it came on! i pushed on all the connections i could see. tthen after work it did it again..i tapped it..it went back on...u guys have any clues?
Old Feb 15, 2005 | 05:32 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
There is only two connections. One blade connector which is the hot lead, the other is the ground wire screwed to the case. I dbout the heater core will affect this because the fan is almost 2 feet away. May be a bad ground, or the hot lead is loose on the connector; start there then work your way back to the HVAC control head.
Good luck
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
MSRed91Camaro
Oct 6, 2015 01:56 PM
64goatman
Sep 9, 2015 01:09 PM
scotrans am
Sep 5, 2015 04:26 AM
