Older style pump w/ reverse rotation
Car: `91 rs
Engine: 352 TPI
Transmission: TH700 R4
How hard would it be to change the impeller on a pre-87 pump to a reverse flow water pump? What i need is a water pump with the assesory bolt holes and reverse rotation for a serp. setup? Also, whats the difference between a long and short water pump and what come standard on a 91 rs.
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
91 RS comes with long pump and reverse rotation. You should have no problem finding a replacement for yours. I'm assuming your looking for a higher flowing one, correct? I would not mess with swapping impellers.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
