water pump bolt help
Old May 2, 2005 | 08:35 PM
IROCZ28dan's Avatar
Car: 1987 IROC-Z
There are 4 bolts that hold the water pump to the block...in a rush when i took my water pump off my 305, and to put the new pump on the 350...i got my bolts jumbled. i found 4 bolts all near eachother that fit the thread/length requirements.
problem is...one of the bolts is really a studded type one with a bolt in the middle. is this the right bolt? if so...can someone tell me which hole it goes into.
its a tpi engine if makes a difference.
Old May 2, 2005 | 09:16 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Top right, the alternator bracket goes on it.
Old May 2, 2005 | 09:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Oh wait, it's an 87. Should be top left then, I think? You'll figure it out when you go to put the accessories back on, anyway.
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
MoJoe
Sep 24, 2015 09:12 PM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
