No pressure???
Old May 15, 2005 | 10:34 AM
BT283's Avatar
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
No pressure???
What is up guys, I have a 91 camaro RS with a 355 and it has a carb. I went to work on the cooling system, I put a BE Cool radiator in it, perma cool fan. BM trans cooler, and a Stage 2 stewert water pump and a 160 degree thermastat. This setup should cool the car off with no trouble but it still overheats. I have found that went i flip the switch on the new Stant rad cap(replaced because i thought the cap maybe the problem and i had a Stant on it before too) there is no pressure coming out of the radiator. Could this be my problem and if so how do i fix it and if not any suggestions?? THanx
db057
Jan 10, 2020 08:55 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Stryker412
Sep 20, 2015 06:59 PM
TBRays98
Sep 6, 2015 05:05 PM
