A/C update...
Old May 31, 2005 | 09:22 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
A/C update...
Well..I found out my biggest problem was a set of cheap azz manifold gauges.I went a got a decent set and tried again.Hooked everything up an started up the vaccum pump.I managed to get down to about 29.5 Hg and then cut the pump off.I wanted to see if the vacuum would hold,so I cleaned up what mess I had which took around 5 minutes.After checking the gauges,the low side was rock steady at where I left it.I did'nt have time to evacuate the system...ran outta daylight.My vacuum pump got kinda hot anyways.Anyone one know if synthetic oil used in compressors will work in this pump.Its a Robinair electric pump.
Ken
Old Jun 3, 2005 | 08:30 PM
black89ws6's Avatar
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
use vacuum pump oil (not ac oil). It's better for your vac pump, and you will pull a better vacuum with it. you can get it at napa
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
