Stroker Motor lunges Forward when A/C clutch engages
Old Jun 8, 2005 | 06:28 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
I have a strong stroker motor . Everytime the clutch from my A/C compressor clicks on my Motor lunges forward a mile or two an hour. Does any one elses car experience any thing like this ?
Old Jun 8, 2005 | 06:36 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
It could be responding to the additional load placed on the engine, but typically the engine bogs down a hair when the AC is engaged. Ive never heard of an engine speeding up in response to the AC cycling.
Old Jun 10, 2005 | 12:58 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
That's normal! Usually the ECM prom is programmed to increase the idle RPM when the AC is turned on. If U know an chip tuner, that can be changed, but I would not worry about it, unless it increases the idle rpm so much that the idle is way too high to deal with.
Old Jun 10, 2005 | 09:47 PM
robsgta's Avatar
Thanks Zap , I had a feeling that was whats going on. It just becomes more aparent when theres a lil more torque involved I guess.. It just gets on your nerves if your on a long cruise..
Rob
mhatfield 14
Oct 24, 2015 07:48 AM
Mickeyruder
Sep 2, 2015 02:45 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
