Water Pump Tips?
Old Jun 14, 2005 | 12:47 PM
srdynamics1's Avatar
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
Water Pump Tips?
I am about to remove and replace my h20 pump any tips or suggestions to make it go smoother.
Torque specs for the bolts?
What type of sealant should I use on the bolts?
Can I ditch the paper gaskets and just use RTV or should I use both?
Old Jul 8, 2005 | 09:30 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
just the paper gaskets will be fine, for torque specs i would look in a chilton manuel...if you don't have one, i highly recommend it, it will be very useful
Old Jul 19, 2005 | 11:22 AM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
30 ft/lbs for the water pump. I use the Permatex copper rtv seal with the paper gaskets. Smear some on both sides and a dab on the bolt threads.
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
