A/C is ice cold moving, stop and it gets hot!!!
Old Jun 21, 2005 | 06:21 PM
bulletboy29's Avatar
Car: '87 Camaro SC
Engine: 305 LG4
Everything is fine until you get into traffic and then it feels like the A/C isn't cold at all. It will freeze you out of there going down the road! Anyone have this problem? What should I check? I idled it up some and that helped a little, but it is still hot sitting in traffic.
Old Jun 22, 2005 | 09:52 AM
Car: '87 Camaro SC
Engine: 305 LG4
TTT
Old Jun 22, 2005 | 10:07 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
make sure the fan kicks on when you turn the AC on.
Old Jun 22, 2005 | 12:15 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
You say that if you idle it up, it gets colder. That is a sign of a weak compressor. It should cool enough while idling. If the air gets warm, I say compressor.
But of course, check that your fans are running, as MrDude pointed out. But you would already know that they are not running, you would overheat fast.
Lou
Old Jun 22, 2005 | 06:27 PM
Car: '87 Camaro SC
Engine: 305 LG4
So my compresser is going out? I have to fix something on this car every week, I guess that will be next. It's like the compressor isn't spinning fast enough at idle. It reminds me of how our blinkers slow down while sitting at a redlight. Thanks for the info!
money-money-money-mon---ey------MONEY!
Old Jun 23, 2005 | 06:19 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
I had this same issue and my fans weren't coming on when they were supposed to. I'd check this first before dropping money on a compressor.
Old Jun 23, 2005 | 07:43 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
What about your freon level. Is your freon low?
Old Jun 23, 2005 | 09:05 PM
Car: '87 Camaro SC
Engine: 305 LG4
Freon is good and I just have the single fan with an l.e.d. that let's me know it's on. They only other thing I can think of is maybe the fan isn't up to par. Is it possible that the fan isn't doing as good a job as it should? The engine doesn't overheat.
Old Jun 23, 2005 | 11:14 PM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
check make sure you dont have debris between the condenser and radiator.
Old Jun 26, 2005 | 10:31 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
A funny thing is that my car acts the same way, although I did ac delete.
Which leads me to a question.
Do you have enough freon in there??
Also, do check your compressor and check for leaks or cloggedge.
Does your guage climb up when ure sitting, does it climb past 220???
Old Jun 29, 2005 | 04:58 PM
Car: '87 Camaro SC
Engine: 305 LG4
Freon is good and I checked for debris around condensor. It had not been used for a few years when I got it. I put a new belt on and charged it up with freon and it worked, just not that well at stops. It seems to be getting better or maybe it's just my imagination. Could I have overcharged it? Would that cause this kind of problem?
Old Jun 29, 2005 | 05:01 PM
Car: '87 Camaro SC
Engine: 305 LG4
Gauge stays well below 220 in traffic.
Old Jun 29, 2005 | 05:21 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
it can be overcharged. That stuff is expensive, but when they go bad you should change out the orifice tube sometimes they get blocked as the compressor gets older with tiny metal shavings. I had leaves and stuff around my condenser i cleaned those up and it helped. But i converted to R134A since it's alot cheaper and almost as good as freon. I replaced the accumulator at the same time as everything else.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Cornholio7979
Sep 20, 2018 02:31 AM
AkDrifted
Aug 17, 2015 07:45 PM
