Big cooling fan, might be the answer for heat too.
Old Jun 27, 2005 | 02:51 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
I am getting a brand new big *** fan instead of the stock one. I'll post some numbers and how it does.
Its one of those Hayden fans that is intended for 368-450 ci engines. I'll use it as my primary and see how it cools everything down.
Here its almost 100 degrees and even my brand new cooling system goes up to 200 because of the lack of grille and, as I belive, inadequate fan.
I'll post results.
Old Jun 27, 2005 | 03:08 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Hayden's biggest, baddest fan only pulls 1300 across a radiator,
1500 free......if you get the Hayden duals, they pull 1600 free,
but that still not very powerful. I sell Hayden, and I get a great
discount on them, but I'd be damned if I'd buy one. Go with a
Flex-a-lite, Spal, Be-Cool, etc....watch how much air they move.
They cost more, but they are quieter and move almost double the
air.
Old Jun 27, 2005 | 05:59 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Spal gets my vote, but I agree on the name brand aftermarket suggestion. I got mine as a NASCAR take-off on eBay for about 50 shipped. Though used, the motor still hasn't gone south on me.
Old Jun 27, 2005 | 06:24 PM
'Shifter's Avatar
Car: 87 Z-28
Got a set of dual Spals my own self-love 'em!
Old Jun 27, 2005 | 10:49 PM
Hey, do you guys use the pusher and puller combo?
How does it work?
I am thinking about one!
Today I went over 220 racing a stupid as5 friend of mine in a chevy colorado. I smoked him bad, and I took him so bad, but my heat went up to 200 on the coolant, and over 220 on the heads. It was 100 degrees here, but if I had some descent fans it would work even better, I think.
The pusher and puller are the only things that I havent tried on my cooling system.
Old Jun 28, 2005 | 12:50 PM
'Shifter's Avatar
Car: 87 Z-28
Puller only on mine-works just fine.....
Old Jun 28, 2005 | 08:08 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
ok now may I throw I dumb question? well I was just curious as to what the stock fans pull as far as CFm goes.
Old Jun 29, 2005 | 01:57 AM
I belive somewhere around 1000cfm's. Which would, somewhat, justify the purchase of haydens.
Now that I think about it, I dont like Hydens, cuz he ruined starwars.
Perma cool pulls up to 2950cfm's with their 16 inch fan for 100 bucks. It sound good to me.
Old Jun 29, 2005 | 09:49 AM
'Shifter's Avatar
Car: 87 Z-28
Yeah, I'd definitely go with the Perma-Cool over the Haydens.
I think I read somewhere on a fan comparison that the o.e. fans
pulled about 700 .
Old Jun 29, 2005 | 10:31 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I'm using two 12" high-po permacool fans. If their rated correctly that's 1650 CFM each, so 3300 CFM total. Those are my pullers. Upfront I'm running a 10" permacool (~900 cfm corrected pusher) on my transmission cooler. When the car is at a dead stop idling and I turn the fans on I still feel air movement all the way back by the driverside rocker still. Course I dropped around $240+ bucks on fans too so that may not be for everyone.
Old Jun 29, 2005 | 12:54 PM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
If you're getting to 220 when driving then you have some other problems. I'm in Dallas and it's 100 degrees out when I drive and only if I sit in traffic and am not moving does it get to 220. And the only not original part in the cooling system is the thermostat.
Old Jun 29, 2005 | 06:59 PM
meridius's Avatar
My car has the warm up in traffic proble, its great as long as Im moving though. I think a new set of fans may be my best bet then since they can pull more air sitting still, maybe even a better slowing pump as well.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
