just charged a\c...green oil..crap
Old Jul 2, 2005 | 05:45 PM
91blue_fire's Avatar
Car: 1985 iroc-z
Engine: 305 tpi with hooker super comp exhaust
Transmission: stock 700r4
charged my a\c at work the other day....held vaccum and everything..everything was GREAT...cold, oil pressure good..fans working condensor working good..then 2 day i lift the hood and see green oil all over the compressor down to the water pump..its a bad leak...bright green..got any ideas?? im hoping its maybe the tracer dye but its yellow...so..i really dunno...the compressor was real loud to at like 2 grand rpm.
Old Jul 4, 2005 | 02:56 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
The "green crap" / "green oil" would be your new freon dripping out of the system. I imagine the system is totally dry now.
Old Jul 4, 2005 | 04:31 PM
Car: 1985 iroc-z
accually..i ran it last night and this morning..its still cold. its not leaking anymore unless i use it..tomorrow when i go 2 work im gonna check it out.
Old Jul 4, 2005 | 09:34 PM
black89ws6's Avatar
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
It sounds like your compressor sneezed.
Your compressor has a pressure relief valve in the back. If the pressure got too high, it could have vented out the back. When a pressure relief valve blows, it spews refrigerant and oil like snot from a sneeze.
The greenish (snot) color is probably UV dye. Put a blacklight on it and see if it glows.
That's the only explanation I can thing of for a blowout leak, leaving spatter marks, and not completely discharging the system.
Falcon50
Aug 22, 2020 03:26 PM
apie2546
Oct 16, 2016 02:24 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
RS Reaper
Sep 27, 2015 07:04 PM
