trans cooler question
Old Jul 13, 2005 | 06:40 PM
SchwarzCamaroRS's Avatar
which hose is the inlet to the radiator. i got a trans cooler and i want to make sure the fluid goes through the trans cooler first, then the radiator, then back to the trans... how would i route that?
Old Jul 13, 2005 | 07:05 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Fluid flows from the bottom port on the transmission to the bottom port on the rad, and from the top port on the rad to the top port on the transmission.
Old Jul 13, 2005 | 07:19 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Yup.
I installed my external cooler on the out line though. My mechanics teacher told me to, because it would be on the ...low pressure line?
I'm thinking I should switch it pretty soon.
Old Jul 13, 2005 | 07:46 PM
TWICEtheRICE's Avatar
Car: 91' Pontiac Firebird
Engine: 388 ci Small block CHEVY (4.060x3.75), Dart Iron Eagle Platinum 200cc, Performer intake, 454 TBI, Long Tubes, True Dual 3" GPs
Transmission: 700R4, B&M, Governer Recal, 20,000 GVW cooler
Originally posted by 305q_ta86
Yup.
My Automobile Technician teacher told us to route the incoming fluid to the cooler on the front of the radiator and then to the internal radiator cooler (heater now) then back to the trans. Its so that you don't over cool the radiator fluid.
Old Jul 13, 2005 | 07:48 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A lot of people have different ideas how it should be done, but there almost doesn't really seem to be a wrong way to do it.
Old Jul 14, 2005 | 12:09 AM
ok, got it all hooked up and routed properly, but i have a minor problem... the trans fluid out (top) i have going into the hard line that goes straight into the trans, but even tightened all the way, fluid leaks out pretty easily.. not a slow dribble... its leaking by the hose, not the threads so its not stripped or anything. BTW its a new aluminum radiator if that has anything to do with it...
Old Jul 14, 2005 | 12:37 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The hard lines are only good for so many retightenings before they need to be reflared it seems. I got tired of fighting leaks so I just replaced the lines with steel braided hose.
Old Jul 14, 2005 | 02:31 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
how much did that hose cost you to replace the hardlines with. i have been thinking about that (getting tired of using the tube bender to bend the lines all over to match the factory bends...
Old Jul 14, 2005 | 02:59 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There's about 6 feet of hose ($30), 4 hose ends ($6) and 4 adapters ($7), so around $82.
Old Jul 14, 2005 | 03:09 AM
ah ok.. considering the hardline fustrations.. might be nice to spend the little bit more.. Although I would have 4 pcs of hose.. 2 coming off the transmission. than two coupled to that and into each side of the cooler.. Mostly for ease of installing and removing the transmission so that you can put the line on before installation and then just connect the rest of the line afterwards without the pain that doing otherwise can cause.
Old Jul 14, 2005 | 03:13 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You don't need 4 pieces, just 3. Leave some slack in the hoses so that you can connect them while the transmission is lowered
Old Jul 14, 2005 | 02:12 PM
ARGH!!! i got it all hooked up, i used soft lines and adapter fittings, all hooked into the trans cooler and the damn thing still gets hotter than a ****... i got a 1705 cfm electric puller fan and when the car sits still, hot as hell... when its moving w/ the ac on... hot as hell... when its moving without ac, its fine... i just cant sit at any lights or run the AC... aside from a water pump, ive replaced and improved EVERY part of the cooling system wtf??
Old Jul 14, 2005 | 02:20 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Were you expecting that adding a transmission cooler was going to make a noticeable difference in engine temperature?
Old Jul 14, 2005 | 02:27 PM
no, i knew that wasnt gunna do anything, just keep the transmission cooler, take some of the load off the radiator... but i did get a new 2 core aluminum one to replace the stock one... thats my main beef...
Old Jul 14, 2005 | 02:38 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
I dont know about others, but my car gets hot (240+ driving!) with over 2000CFM of fans here (Mojave Desert).
Hope that is taken car of soon (dual fans) or im putting my thermoclutch back on
Old Jul 14, 2005 | 02:43 PM
with a 160* T-stat, 2 core aluminum radiator and 1700+ cfm... i shouldnt be getting above 180*... and i live in Phoenix, AZ... its about 110 outside right now..
Old Jul 14, 2005 | 02:47 PM
Car: 85 Trans Am
Of course we also dont know what you mean by "hot"... 190?
Id say we you live, id be happy with 210 in traffic
Old Jul 15, 2005 | 05:31 AM
no, over 220... but with the 160, it stays around 160 when im moving... its just when i sit still that it zoinks and starts the whole overheating thing...
Old Jul 16, 2005 | 12:53 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
have you changed your fan switch to one with a lower temp?
Old Jul 16, 2005 | 12:54 AM
i run a Driver control switch... i control my fan, no fan thermostat
Old Jul 16, 2005 | 05:26 PM
How would only 6ft of hose go from the transmission to the radiator and back again? Right now i have a 52" line and a 63" line in order to make it from the tranny to the radiator.. so only 72" would be a bit short, unless you just have it running into your cooler and not the radiator portion.
Old Jul 16, 2005 | 06:51 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That should have been 6' x 2
Old Jul 16, 2005 | 06:54 PM
oh. that makes a bit more sense lol
Old Jul 16, 2005 | 06:56 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I'll post a disclaimer: Measure what you need instead of ordering based on my eyeballed measurements.
Old Jul 16, 2005 | 07:31 PM
72" either way should be more than plenty (especially for the lower one)
84z96L31vortec
Aug 20, 2017 12:16 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
