stupid cooling question
Old Jul 18, 2005 | 09:04 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
just installed my new motor from a 305 to a 350. now its over heating. question is i have 170 themostate with a stock prom would that prevent it from opening or could it just be i have too much water and not enough antifreeze???????
Old Jul 23, 2005 | 03:04 AM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
your thermostat has no relation to your prom, so no, your swap will not affect your cooling. keep it simple...start with your coolant level. if it is good, which you should have some overflow to reservior,... move to leaks. check for any leaks. if there are no leaks, move to your cap...have it tested to see if it maintains pressure, and vacuum for cool down. if that is fine, have your coolant tested. there is a scope which you drop a drop of your coolant in and it determines your protection points (freeze point to boiling point). you can also check your thermostat to make sure it opens at specified temp...keep me updated
Old Jul 23, 2005 | 07:15 AM
jayk2k3's Avatar
Car: 85 camaro z28
just pulled the top radiotor hose and its bone dry, so im assuming the problem is thermostat is bad, correct me if im wrong?
Old Jul 23, 2005 | 10:09 AM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
could be, pull it out and stick in a pot of hot water and bring it to boil, see if it opens
Old Jul 24, 2005 | 01:02 AM
jayk2k3's Avatar
Car: 85 camaro z28
got a new thermostat and it works now but shows the car is still over heating. i think the gauge is bad, cuz the car doenst seem to be overheating and runs good now.
Old Jul 24, 2005 | 01:45 AM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
if it is over heating you will notice boil over into the expansion tank (reservoir). you can aslo check to see if your t-stat works by squeezing the pressure (top) radiator hose. it should be stiff when the t-stat opens
chazman
Aug 28, 2018 03:25 PM
Cleotiz
Jan 6, 2018 08:56 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
Leggman1
Aug 6, 2015 04:15 AM
