rad fan only works with ac on!help please!
Old Jul 21, 2005 | 10:21 PM
camarodh's Avatar
Car: 86 camaro z28
Engine: 305 4bbl
Transmission: 5spd standard
ok i just picked up a 86 305 4bbl 5spd z28 and the rad fan only kicks in at around 230-240 F i really need to get this car working good and driving around with the ac on constantly will suck. i need a very detailed step by step procedure of how to fix this, it would be very much appreciated. e-mail me at pontiacdh@hotmail.com
thanx...............
Old Jul 21, 2005 | 10:35 PM
transamracer's Avatar
Car: 1988 Trans AM GTA
Engine: 5.7L Tuned Port Injection
Axle/Gears: 9 Bolt 3.27
sounds like your temp. switch for the fan isn't working. I'm not sure where it is on your car. anyone know where the temp switch is on the TBI Models?
Old Jul 22, 2005 | 09:08 PM
camarodh's Avatar
Car: 86 camaro z28
Engine: 305 4bbl
reply
thanx, i will look it up in my camaro book. your awesome
Old Jul 22, 2005 | 10:07 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Are you saying the cooling fan kicks on either when the AC is turned on, or by itself around 230*-240*? If so, it sounds like the coolant fan switch (what transamracer mentioned) is working, but it's the stock one. I can't tell you why, but GM decided to kick the fan on on the single-fan 3rd gens very late.
They make aftermarket fan switchs that will turn the fan on much sooner, usually around 200*. There are many different companies that sell them, but this is the cheapest I have found them. I'm using this exact fan switch and it's working perfectly so far, it's part number 609-106:
http://www.madvet.com/shop?frame=1.138.944
The coolant fan switch location is the same on all the V8 3rd gens. It's in the passenger side cylinder head right in between the #6 and #8 spark plugs. If you want a step-by-step guide on replacing it, just let me know.
Old Jul 23, 2005 | 09:09 PM
camarodh's Avatar
Car: 86 camaro z28
Engine: 305 4bbl
that helps better i probably will buy one of these and if u have a guide please email me it at pontiacdh@hotmail.com thank you.
Old Jul 24, 2005 | 02:00 PM
Benm109's Avatar
Engine: 305 TBI
Email sent.
eightsixseven
Dec 16, 2024 01:50 PM
91 rally sport
22
Apr 5, 2016 05:06 PM
Wade787b
Sep 29, 2015 01:15 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
