Help!! I'm making my own gravy.
Car: 89 camaro rs T-top
Engine: V8
Transmission: auto
It's 94 degrees today and I can't shut the heat off. I've changed the vacuum control in the center console. The wire that slides in and out on the temp control slides. I believe the other end of the wire goes to the heater core. So I gots to find where the heater core is. It may be unhooked. If that doesn't do it I'll put a ball valve in the heater hose to stop the flow.
So how do I get to the heater core? All info will be appreciated. savoo
Car: 81 Corvette
Engine: 355, ported vortec heads
Passenger side, under the dash againts the fire wall.
If you look from the engine side you can see where 2 hoses go into the fire wall. That is where the heater core is. You can just get an elbow to join those 2 hoses together and divert the flow until you can figure out what the problem is.
mustangman65_79
Aug 11, 2015 03:17 PM
