eBay "fan switch"
Old Jul 30, 2005 | 10:10 PM
dan_o_89_rs's Avatar
Car: 89 camaro rs
Engine: 305 tbi
eBay "fan switch"
has anybody used anything like this? and/or can anyone explain to me how this works?
http://cgi.ebay.com/ebaymotors/82-92...spagenameZWDVW
i am obviously interested in a fan switch. ive searched around and didnt have any luck. i hate to get another fan switch thread started, but i dont know what i should do... thanks.
Old Jul 31, 2005 | 04:59 PM
Car: 89 camaro rs
Engine: 305 tbi
bump...
anyone?
Old Jul 31, 2005 | 07:06 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Looks like a two wire temp switch, some common industrial switch maybe. Wire with big terminal goes to a ground, other wire splices into the wire for the high temp switch that's on the car now. Note this new one goes into a plugged hole on the top of the water pump, might check to see that yours has this as finding a tapped hole into the water jacket is tough sometimes.
Old Jul 31, 2005 | 07:22 PM
Car: 89 camaro rs
Engine: 305 tbi
so it is basically using a second CTS, which will be in the water pump? im guessing this would throw the ses light, what do u think?
Old Aug 1, 2005 | 08:33 AM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
I think you just need to go with this part instead. It is the same price, comes with the switch, relay, and harness. A much better deal.
derale fan switch
Old Aug 1, 2005 | 09:24 PM
1986T&A's Avatar
Car: 1986 Trans Am
I just got this part this weekend. I have an 86 TA with 305 TPI. It works great, my fan actually comes on and keeps the car running at a nice temp. It fit right into the plug on the top of the waterpump, however I cut the knock sensor wire by mistake as Icouldnt find my switch underneath there. I just cut the wire from the fan relay switch under the air cleaner and it works great. The part is simple and really works great for me. Not sure how much different your 305 is, but mine is running cool now. I would recomend it.
Old Aug 2, 2005 | 08:08 AM
Car: 89 camaro rs
Engine: 305 tbi
this does seem better. i like those temps better. on180 / off170.
1986t&a, did your SES light come on? what temp thermostat are you running and what temp does your car run at?
Old Aug 2, 2005 | 09:58 AM
vrtc350's Avatar
Car: 81 Corvette
Please, do tell! I'm getting ready to order this setup.
Old Aug 2, 2005 | 09:25 PM
1986T&A's Avatar
Car: 1986 Trans Am
MY ses light has been on since i have had the car. I get a 34 code, but the MAF seems fine and it runs fine. The car runs at about 200, where is where it seems to run best. I am not sure of the lower temp one, that fan would be running all the time to keep it in sucha short temp holding. That is just my opinion, maybe it woud be better, but mine is running very good now and I am pleased.
Old Aug 3, 2005 | 01:00 AM
Winger4800's Avatar
Car: 2003 Corvette
Transmission: one that has 6 speeds
Wouldn't buying a cooler fan switch for the one in the pass side of block be better instead of "hacking" this stuf on our cars??? by installing one of the kits above it basically puts the switch that is on the pass. side block out of work.....
Old Aug 3, 2005 | 07:12 AM
vrtc350's Avatar
Car: 81 Corvette
With no ECM, it's out of work anyway. I want a cooler temp than what the factory had set up.
Old Aug 3, 2005 | 04:50 PM
1986T&A's Avatar
Car: 1986 Trans Am
I think the advantage of this switch is also that it is easier to install. The underneath of our cars is pertty cramped. This switch was very easy to put in, and as stated the ecm doesnt control this so basically the stock part is just sitting there "dead". If you put a new switch in the original spot, it requires draining fluid and can get pretty messy.
Old Aug 3, 2005 | 06:07 PM
vrtc350's Avatar
Car: 81 Corvette
Thats true. I have an advantage though. My 355 is finished on the stand, the 305 is out and I am cleaning up the engine bay. No mess for me!!!
Old Aug 10, 2005 | 11:27 PM
jack_sparrow's Avatar
Car: 1985 Camaro
Engine: 350 bored 40 over
Transmission: 700-R4 Race prepped
I bought one from Painless that goes on at 180 degrees and off at 210 i think?! But anyway, it's never gto anywhere close to overheating.
jack
Old Aug 11, 2005 | 07:16 AM
vrtc350's Avatar
Car: 81 Corvette
Well now I'm thinking of buying the one that is adjustable. A friend of mine seems to think that the fans will be running all the time in this nasty summer heat (90*+)
1986T&A, how much are your fans running with that original switch I posted up? Also, what temperature is your t-stat that you are using with this kit?
Old Aug 12, 2005 | 05:45 PM
1986T&A's Avatar
Car: 1986 Trans Am
I think it is like 170, not sure how mcuh the fans run, but the temp is stayingnice and even. But the car never gets hot running down the highway so I would imagine the fans not runnugn then, running around town, I am sure it is on alot to keep it cool. But hte temp doesnt fluctuate.
Old Aug 13, 2005 | 09:28 PM
Car: 89 camaro rs
Engine: 305 tbi
jack
im hoping u got those temps backwards.
Old Aug 13, 2005 | 10:24 PM
vrtc350's Avatar
Car: 81 Corvette
Funny, I was shopping through Summit.com. That same kit is listed on Summit just like that 180 on, 210 off.
I don't know.
Old Aug 13, 2005 | 10:29 PM
Car: 89 camaro rs
Engine: 305 tbi
hmm thats interesting, i guess it just gives up hope if u reach 210. haha
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
GageBrand
Oct 22, 2015 02:30 PM
Fanatic1074
Oct 2, 2015 03:47 PM
