K&n throttle body air filter
Old Jul 31, 2005 | 06:51 PM
89TPI350's Avatar
Car: 1989 Formula 350
Transmission: 700-R4
I am interested in getting the K&N throttle body air filter and completely getting rid of the stock air box. I own a 1989 formula 350, but this filter only clamps to a 90-92 throttle body without modification, it says that it will work with 85-89 TPI that has been converted to speed density. I dont have alot of knowledge about the newer speed density setup. How do I convert it so I can use this air filter? and has anybody used it and how did it work for them? Thanks , Randy
Old Aug 1, 2005 | 11:41 AM
firebirdjones's Avatar
WOW!
Geewiz, you want to convert to speed density just so you can install an air filter on the end of the throttle body? I don't think I would go through all that work just for an air filter. Just live with the MAF sensor setup and install a good cold air intake setup, alot less headache and it will pull in cool air instead of hot air blowing off of the radiator. Just my 2 cents. Larry.
Old Aug 1, 2005 | 12:48 PM
89TPI350's Avatar
im 16 and i just thought it looked cool, and that it would be no big deal to just switch it out haha, i didnt know they made a cold air intake ive been looking for one, yeah that does make sense now that you say that thanks
Old Aug 1, 2005 | 01:11 PM
filters
Thats cool, those air filters on the end do look pretty good. The easiest thing to do would be to install a cold air kit though and keep the MAF system on the car. I believe it is SLP that offers a cold air kit for the Firebirds. Do some searching and you may be able to find more info on it, I believe that there are alot of people on here that have made their own cold air kits for their Firebirds also, that may be another option to look into if you are on a budget. Hope that helps, Larry.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
