installing fan need help wiring
Old Aug 4, 2005 | 11:29 AM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
ok i bought the 90s electric ford taurus 2speed fan, and i want to wire it into my car, and lose the little existing fan. i bought an adj. fan switch that i can set the temp to turn on and off. now i have a wiring diagram i found but im confused on where to wire it to. either the 2 wires coming off the stock fan( power and ground?) or some others? heres the diagram please help
[img]
this will allow me to switch on high fan manually and low with be controlled by the thermostat. now the 40amp squiggle on the left....is that a inline fuse?? and i need someone to explain the whole dotted line box marked fan control. thanx alot! oh and is this gonna work?
Old Aug 4, 2005 | 12:17 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
THat will do exactly what you want from what you said. Auto turns the low motor on/off automatically while high bypasses the whole auto controller.
Squiggly lines are inline fuses. Your stock fan has 2 wires, positive and ground. That fan in the diagram has high (positive), low (positive), and a shared ground. The fan control box is just a relay that is triggered by a Temp Sensor. Must be a whole external unit for a Ford Taurus, its built into the ECMs in our third gens AFAIK.
Old Aug 4, 2005 | 12:42 PM
7plagues's Avatar
so could i take the positive off the fan and wire this up accordingly? my car is goin carb and the ecm is gonna go probably. also i have the thermo switch control.
so under fan control(that part looks confusing...) what is the 30amp relay doin? its like making a door in the low speed wire. what does this mean. im really sorry but i dont know what all these symbols are.
Old Aug 4, 2005 | 12:46 PM
7plagues's Avatar
what size wire should i use?
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
rocn7roc
Sep 21, 2021 02:16 PM
Caspar
Jun 19, 2016 11:19 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
