Dual Fans for LT1
Old Aug 13, 2005 | 02:10 AM
DF'sCamaro's Avatar
Car: 1992 RS Black
Engine: 305 TBI(LT1 swap soon)
Transmission: T5 (T56 for LT1 swap)
Axle/Gears: 4.10
Dual Fans for LT1
Was wondering if anyone’s knows if the harness/plug on the 3rd gen Dual Fans is the same as the 4th gen Dual Fans? Cause I am going to be doing my LT1 swap soon and wondering if a 3rd gen Dual Fan setup would wire up without messy splicing? Or does anyone know if the 4th gen dual fan setup fit on our 3rd gen radiators without major modifications?
Old Aug 14, 2005 | 01:29 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: Dual Fans for LT1
Yes
Connectors are the same for either.
Yes it will
Old Aug 15, 2005 | 03:36 PM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
did you have trouble mounting the 4th gen fans to our third gens? is it an easy install? i can hook them up i just need to know if the mounts are the same. thanks!
Old Aug 19, 2005 | 03:05 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
They mount different, but getting them to stay in place in a thirdgen is quite easy and doesnt require a whole lot of work. The connectors are also the same as I stated.
Old Aug 19, 2005 | 03:19 PM
wdigitog's Avatar
z-28*****: any pictures of your fan mounting? did you need to make brackets?
Old Aug 21, 2005 | 10:37 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
yes the lt1 fans work great. much better than the unshrouded 3rd gen setup. you can actually hear them working and see the temps drop. what i did was mount the lt1 setup upside down(at least vs if it was in a 4th gen) and modified a single fan upper bracket to make it work. if i have some time i'll get a pic up.
Old Aug 21, 2005 | 03:01 PM
wdigitog's Avatar
mystik, that would be awesome!
Old Aug 29, 2005 | 02:09 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
i swapped in a 4th gen radiator to make the fan install simple.
they clip on the factory mounts.
radiator hose change is a must afterwards.
Bubbajones_ya
Jul 6, 2024 08:32 PM
codeysabatini
Nov 10, 2015 04:07 PM
scotrans am
Sep 5, 2015 04:26 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
