Elec Fan Doesnt Work Can I Use A Belt Fan
Old Aug 13, 2005 | 10:11 PM
Repzard's Avatar
Car: 86 Z28
Engine: TPI 305
I have a question: im sick of the problems with eletric fan
on my 86 camaro z28.
Engine is:305 (F code)with TPI
My question is I have (2) 85 camaros with 305 (carb) and they both have belt fans to cool radiator.
On my 86 Z28 it looks like a belt fan could be mounted on pully with no problem.
1) By unhooking the eletric fan would that trigger my check engine light to come on?
2) Will belt fan work ok with TPI Setup without any conficts?
3)Does it Rob HP & Torque?
4)Would cooling be better were its running all the time and there are nice after market belt fans to replace stock?
I know i can run electric fan by a toggle switch but worring to turn it off and on is just a pain and my opion electic fans are just not reliable.
Thank You For Any Help.!!!
*CHEVY.......Let Camaro's Live*
Old Aug 14, 2005 | 06:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I didn't like the toggle switch for the same reason, so here's what I did (though I'm afraid the link won't answer most of your questions):
https://www.thirdgen.org/techbb2/sho...hreadid=309711
JamesC
Old Aug 14, 2005 | 10:22 AM
Repzard's Avatar
Car: 86 Z28
Engine: TPI 305
Thank you James C
I did see that on the message board.
the problem is the electric fan doesn't seem to come on at all even when i put my A/C on.
I didn't try powering up the fan directly to the batt to see if the fan was the problem yet.
If fan does power up would that be the problem of the relay?
where it doesnt come on with A\C (when i read on board it should) ?
This is the whole reason im wordering if a belt fan would work not having to deal with electric fan problems
(My Z28 only has 1 fan if that helps)
Old Aug 14, 2005 | 11:49 AM
JamesC's Avatar
Guessing, I'd say you're correct: fan motor or relay.
JamesC
Old Aug 14, 2005 | 08:49 PM
Repzard's Avatar
Car: 86 Z28
Engine: TPI 305
Thank You Again JC
Today i replaced the relay, engine got up to about 220 degrees and the fan came on
And after really looking at what i would have to do to put a belt fan on would really be tuff do to A/C lines running across radiator wich mean i would have to take the whole A/C system out of the 85 camaros
so for now I guess im stuck with this electric fan
Thanks Again James C for all your help
**Chevy..Let Camaro's Live**
Repzard
Old Aug 27, 2005 | 10:42 AM
JDF-Z28's Avatar
Car: 1983 Z28
Engine: GMPP 350, 92 TPI
Axle/Gears: Auburn gear posi, 3.08
No belt fans!
Dude, glad you got you electric fan working again. Just wanted to share, had the belt driven fan setup from the factory. I switched over to dual electric fans and now I have a cooler running car and you can definately feel the power gains by not having to spin that heavy fan and clutch setup or having to turn the fan all the time.
Old Sep 1, 2005 | 06:31 PM
My1986IROC-Z's Avatar
Car: 1986 Iroc-Z
Engine: 305 TPI (used to be Carb)
Where exactly is the fan located at, my buddies is bad to we think.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
scottmoyer
Aug 9, 2015 10:18 PM
Leggman1
Aug 6, 2015 04:15 AM
