New Summit Direct Fit Aluminum Radiator
Old Aug 20, 2005 | 09:53 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I just got the new summit catalog and they have a direct fit radiator for our cars now for $320, part number SUM-380455, Click here to check it out. I just wanted to see what you guys though of this radiator.
Attached Thumbnails New Summit Direct Fit Aluminum Radiator-sum-380455_w.jpg
Old Sep 12, 2005 | 08:59 PM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
Looks nice, I'm posting to get this thing recirculated to the top of the list, wanna know about it too, which summit catalog did that first come in? I don't remember seing it in any of the catalogs I have. Someone with some knowledge help me and this guy out.
Old Sep 18, 2005 | 08:36 PM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
It's made by northern, I have one in my car. Same fittings, blue anodized filler neck, 3 dimples on the passenger side. It fits good in my serp belt camaro, not many real mods needed, works great, built well, I did a post on it a while back called "Northern Aluminum radiator=The sheezy" it'll come up with more detailed info and a lot more people's claims. Should still be within the first 5 pages on this section.
Old Sep 18, 2005 | 08:41 PM
Engine: Your Momma
https://www.thirdgen.org/techbb2/sho...hreadid=258752
There ya go.
Old Jul 12, 2007 | 03:48 AM
70gmc's Avatar
Car: 1970 GMC LWB Street strip
Engine: 383 stroker
Transmission: 350TH
Axle/Gears: 12 Bolt 4:11
Re: New Summit Direct Fit Aluminum Radiator
So i got one question. It says it fits automatic trannys becuase of the built in cooler. Would it work in a manual car without those hooked up. or possible us those hook ups as a oil cooler or something? Just curious.
Old Jul 12, 2007 | 09:40 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
You can use it without using the trans cooler. You may want to install 2 plugs to keep the interior of the cooler clean in case you need it at a later time. Not sure about using it for an oil cooler, I think the fittings at the radiator may be too small and restrict the oil flow. The radiators should be available for manual trans/no cooler and probably some cheaper.
Vintageracer
Jan 10, 2020 05:33 PM
LilHot
Aug 23, 2015 09:36 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
TreDeClaw
Aug 14, 2015 06:58 PM
