Passenger Side Temp Switch Alternatives
Old Aug 28, 2005 | 06:56 PM
89 CamaroIROCZ's Avatar
Hi guys, trying not to buy the derale kit. I'd like to find a temp sending switch that maybe could be bought through pep boys or autozone. While searching I found one that turns on at 220, but I'd like one to turn on a little cooler than that, maybe 200 or 190. Something like this, I know autozone must have one of these. Heres an example from Summit ..
Thanks,
Matt
Old Aug 29, 2005 | 01:39 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
I dont think autozone would carry that. They mostly carry stock parts. Your way better off getting it from summit. Thats where i got mine from. I got the Jet temp switch. I love it. it kicks the fan on around 190-195. way cooler than stock. Get it from summit.
Old Aug 29, 2005 | 09:05 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I had to order mine from Summit as well. THen I replocated it to a "free" port on the front of the intake manifold so that I'd quit frying the wires for it on my headers.
Old Aug 29, 2005 | 09:20 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you know, if you want to THINK about it, and not waste money, you could just order one for a truck... spend around $8-$12... sure it doesnt come with a Jet sticker, but its the same part
lol
jet doesnt MAKE anything, they just rebadge the same part that your local store probly already has.... for a diffrent app... GM didnt make the fans kickon that late on EVERYTHING...
Old Aug 29, 2005 | 09:40 AM
Exactly! I found a stock sensor that kicked on cooler for a replacement if you still have tpi, but i really want to find one with the spade terminal. Maybe I'll go searching at pep boys, *** they are such idiots tho. No offense to anyone that works there..
Matt
Old Aug 29, 2005 | 10:39 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
I didnt know that i could of got one from autozone for a different app. Dang well there goes my 36bucks.
Old Aug 29, 2005 | 11:29 AM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Search for Grand National switches. They fit and come on at cooler temps. I got a 220 on/ 210 off for mine cost $8. They had a lower temperature one too, except it cost more.
Old Aug 30, 2005 | 12:30 AM
Does it have the spade terminal or the gm weird circular fitting they put on the TPI's?
Old Aug 30, 2005 | 12:41 AM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
Just a thought. This is the one i bought last night.
http://www.madvet.com/shop?frame=1.138.944
It is the corvette model, which is usable for all tpi motors.
12bucks versus 45. I bought the JET one for my IROC in the states many years ago. Now I am wiser and 35 bucks richer. shawn
Old Sep 1, 2005 | 09:39 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
I bought a universal fan switch from Advanced Auto a while back. Its got a probe that goes into the back of the radiator, which leads to a box thats got a + and - to the fan, and a constant 12v. Its adjustable too, I forget what all temps its good to. Might wanna check that out if your not sure exactly what you want your temp settings to be.
Old Sep 2, 2005 | 06:31 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm not sure that the following is what you want, but it does have spade terminals:
https://www.thirdgen.org/techbb2/sho...hreadid=309711
By the way, when I was researching the above, IIRC, I found a single spade terminal from BeCool.
Well, it's not a spade, but it might be an alternative:
http://www.becool.com/products_accs_fanacc.cfm
P/N's 75029 and 75530
JamesC
Old Sep 2, 2005 | 10:42 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
lol, i kinda like that circle fitting...
if you have to replace the connector, you can put some spade terminals on them..
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
Cameeeero
Aug 20, 2015 03:06 AM
Nj1987
Aug 19, 2015 08:26 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Street Lethal
Aug 14, 2015 08:25 PM
