coolant drain plug
Old Aug 30, 2005 | 12:08 PM
schimek's Avatar
coolant drain plug
I have a 1994 Trans Am and am trying to drain the coolant from the block. The drain plug is a 9/16" but it is on there tight. Do I risk using a cheater bar to break the drain plug loose and maybe break the plug? Has anyone else had trouble with breaking it loose? I haven't tried the knock sensor yet.
Old Aug 30, 2005 | 02:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Try heating it up with a torch first, perhaps. After you get it out, replace it with a petcock to avoid having this problem again.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
89 formula TPI
Oct 6, 2015 08:40 PM
ericjon262
Sep 11, 2015 06:07 PM
89 formula TPI
Sep 7, 2015 11:06 AM
