What temp to program the PROM at for fans?
Old Sep 8, 2005 | 04:41 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Need opinions on this setup, help me out?
I have a 355 with some mods (heads, cam, holley stealth ram, etc). I have a single fan right now that I want to replace with a dual fan setup. I believe the dual fan will flow more air so I'm just going to wire them in parallel- so they both turn on/off at the same time. Would it be plausible to have the fans completely controlled by the ECM since I'm burning a custom PROM for it. So does that make sense or should I pick up a fan switch? Also, if I were to plug the fan switch hole, what size are the threads/what length, etc? I don't really want a manual switch since it's just a hassle for a daily driver.
Bubbajones_ya
Jul 6, 2024 08:32 PM
corey8084
Sep 17, 2015 02:56 PM
gta892000
Sep 16, 2015 12:37 AM
86IROC112
Sep 11, 2015 04:04 PM
85Special
Sep 3, 2015 04:21 PM
