Dual Fan operation?
Old Sep 13, 2005 | 02:20 PM
89IROCZTPI's Avatar
Car: 1989 IROCZ
Engine: Rebuilt 350 TPI
Dual Fan operation?
I did some searchin around and couldnt really find anything to answer my question. Neither of my fans come on, the car runs very well and doesnt overheat, until im stopped and idling and then the heat climbs on up. The fan will come on when I jump the computer port, so I know at least one fan motor is good. Just replaced the relay and going to try the coolant temp sensor(even tho its relativly new). My question, other than trying to figure out whats wrong, is does the secondary fan only come on when the switch on the pass side head tell it too and does the primary fan have to be on for the secondary one to come on also? Thanks for any info!
Old Sep 13, 2005 | 05:01 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Secondary fan is set at 225* F by the ECM or if the AC is on (from what I recall by memory). I don't think it comes on at the same time as the primary (hence the name).
Old Sep 13, 2005 | 08:43 PM
89IROCZTPI's Avatar
Car: 1989 IROCZ
I understand that, basically what im trying to figure out, is if the primary fan has to be on first before the secondary can turn on at its designated temperature. Trying to figure out if I just might have a problem with the primary fan or if both are screwed up somehow. Thanks!
Old Sep 17, 2005 | 05:24 PM
89IROCZTPI's Avatar
Car: 1989 IROCZ
Did some checkin around, replaced the 20A fuse by the relays, all the wires check good for continuity. The fan comes on if I put the computer in diagnostic mode, so Im assuming that means the grounds are good from the computer to the fan and that the motor works. Should I be hunting for a bad ground? Just looking for whichaway to go from here, thanks for any help!
Old Sep 25, 2005 | 09:32 PM
89IROCZTPI's Avatar
Car: 1989 IROCZ
Anyone? Really wanna figure out whats wrong. Had someone tell me to ground out the secondary fan sensor, but theres only one wire going to it? Looking for a way to go from here, thanks for any help!
Old Oct 1, 2005 | 06:49 AM
89IROCZTPI's Avatar
Car: 1989 IROCZ
Havent really found the problem, but whats weird, I had shut if off last night while my wife got the kid from the babysitters, so I turn the key forward to listen to the radio, and the fan comes on?
Old Oct 1, 2005 | 07:55 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
On my 89, the secondary fan will run without the primary coming on and the high temp sensor will actually turn on both fans, at about 135 degrees, way hot. And both fans run on the AC high pressure switch. Grounding that single wire on the passenger side sensor in the head should make one or both fans come on for sure.
Old Oct 7, 2005 | 10:19 AM
89IROCZTPI's Avatar
Car: 1989 IROCZ
sorry took so long to reply, busy busy busy, thanks for the reply, just one question, what would be the "proper" way to jump the wire to ground?
Bubbajones_ya
Jul 6, 2024 08:32 PM
Kylej68
Exterior Parts Wanted
Sep 28, 2015 10:00 AM
ivan1137
Sep 23, 2015 09:08 AM
scotrans am
Sep 5, 2015 04:26 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
