how hot is too hot?
Old Sep 17, 2005 | 07:55 AM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
how hot is too hot?
i just installed a water temp gauge in my car and replaced the valve cover gaskets but the water temp gauge reads 220. i started the car fine nice n cold. went to 180 no wories BUT as soon as i started driving the temp started to rise up and up and it hit 220 and i had to wait a few seconds to find a place to pull over but i did and it just stayed right at 220 the whole time. i let it cool off and luckly i was just about a minute or so from home so i crossed my fingers and inched it home keeping out of the throttle but it still went up to 220 and stayed there again. Is that normal? didnt budge past 220.
Old Sep 17, 2005 | 03:06 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
it won't hurt anything. what thermostat are you running? try a 180
Old Sep 17, 2005 | 08:51 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
220 is fine, my car runs 220 when its real hot outside and im driving around the city. OTher then that i am usually on the highway and i dont even pass 200 on the highway. IF anything my car is running to cool and yours is running normal . Hey ur saving gas
Old Sep 18, 2005 | 05:45 PM
xplane's Avatar
Engine: 2.8 MFI
if i dont have an airdam will that make a difference?
Old Sep 18, 2005 | 09:07 PM
FieroGTA's Avatar
A huge difference.
Old Sep 19, 2005 | 11:23 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
I ran a MINIMUM of 220 all the time until I replaced my air dam. Now, unless it's a stupid hot day, I run whatever temp the thermostat is. I drilled four 1/8" holes in a 180* thermostat and now run maybe 170* on all but the hottest days as long as I'm either moving or the fan is on.
Old Sep 21, 2005 | 11:48 AM
zrated383's Avatar
Car: '88 IROC-Z
Engine: StealthRammed 355
Originally posted by FieroGTA
A huge difference.
x2...I am going to get a new one or put my old one back on because I noticed a pretty significant increase in my water temp...
Old Sep 21, 2005 | 12:06 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
It's one of those things that a lot of people remove for one reason or another & it makes an enormous difference. Without it, most of the air goes underneath the car instead of through the radiator. My car was missing one when I got it. The previous owner kept complaining about the overheating. The day I put it on -- never again and it's been a year.
Old Sep 22, 2005 | 11:08 AM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
Transmission: 4 Speed Manual
I spent $35 at hawksthridgen for an air dam. My car has run 30 degrees lower since. Funny what a diference a piece of plastic can have.
Old Sep 22, 2005 | 01:38 PM
firebirdjones's Avatar
air dam
Yes,,,especially on a car that has no front grille area. Larry.
Old Sep 27, 2005 | 05:39 PM
chevymetal's Avatar
Car: 1985 Chevrolet Camaro IROC-Z28
Anyone know where to order an airdam? My GM Dealers in MI never have any parts that I want, and are not willing to order them. They tell me the closest unit is located in "xxxx city, in xxxx state" and that I would have to go get it myself.
chevymetal's Avatar
Nevermind, I didn't see Tripper511's post.
Old Sep 30, 2005 | 12:17 AM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Be absolutely thankful that your third gen is topping out at 220. That is a perfectly fine temp, perfect normal operating temperature, a desired commodity on these cars. Just read about 20 more posts in this tech and then go buy a lottery ticket you'll see what I mean
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Thaney9
Oct 24, 2015 07:26 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
