A/T trans + rad upgrade
Old Oct 7, 2005 | 10:39 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
ok so this is prolly a dumb question but im going thru a custom build... i have a 400hp 400ftlb 350cid..... backed by a 700r4
i want to upgrade radiators. and i also plan on running a performance built 700r4 later on..
i want to know if its alright to get a regular hipo radiator sans the internal trans cooler and just run an air cooled trans cooler in front of the radiator?
Old Oct 7, 2005 | 11:22 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I ran my trans cooler external of the radiator, and planning on running external of my C&R (which doesn't have provisisions for it anyway). You'll be fine.
Old Oct 10, 2005 | 11:46 AM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
I have a hayden 5 pass (i think its 5, havent seen it in a while ) and a northen 31x19, trans is cooled externally, actually keeps it cooler, 140-170.
Old Oct 10, 2005 | 12:30 PM
crazymex83's Avatar
Car: '88 Firebird Formula 350
Engine: L98 TPI 350
Transmission: 700R-4
When you say that you have a Northern 31" x 19" radiator do you mean you purchased the radiator from Northern Auto Parts and or that Northern is the company that makes the radiator? I looked at Northern auto parts and they sell a 31" x 19" radiator that is built by Be Cool and is a universal fit but from what I understood is that they were not designed for vehicles like the firebird/camaro due to the angle that the radiators are installed at unlike a truck with a radiator set straight up. If it works it works, I just wanted to clarify.
Old Oct 10, 2005 | 01:11 PM
Car: 85 Trans Am
http://store.summitracing.com/partde...t=SUM%2D380331
Those are made by northern radiator
A 31x19 can fit, just a little work.
At summit they now sell a direct fit for the camaro/firebird with tranny cooler for like $300 or so.
Link: http://store.summitracing.com/partde...t=SUM%2D380455
Old Oct 10, 2005 | 01:38 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Thanks very much... thats a great help that i can now spend $200-$300 on a good radiator and geta separate Trans cooler....
instead of $500+ for one that has a internal trans cooler...
Orr89RocZ
Apr 25, 2016 08:28 AM
BlackphantomZ28
Apr 24, 2016 08:14 AM
91 rally sport
22
Apr 5, 2016 05:06 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
