reverse water pump ??
Old Oct 10, 2005 | 03:52 PM
scott 87z28's Avatar
I have a 1987 z28, took the 305 out used the same water pump on a I believe a 1991 caprice roller 350 block. (cop car)
Iam wondering how do I tell what the old water pump is, rev, standard??
is there a difference in the block or is only in the water pump?
If I take the rear plate of the water pump what direction should the veins be ?
thanks
Scott
Old Oct 10, 2005 | 03:59 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If you have V-belts now, you need a standard rotation water pump. The Caprice motor will most likely be a reverse rotation, being a serpentine.
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
MoJoe
Sep 24, 2015 09:12 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
