Help.. Whats This Part Called?
Old Dec 5, 2005 | 02:50 PM
eektech909's Avatar
alright.. my car overheated today so it was replenished with anti-freeze etc and it tried to overheat again in about 5 minutes. I found the broken piece but i dunno what the parts called. It has an "F" shape to it. The water comes into it from the engine and spits off to goto either the heater core, or back to radiator. The male piece attached to the hose that comes from the engine cracked off so the anti-freeze was just shooting out all over the place.
if anyone knows please let me know a.s.a.p. so i can fix it. thanks
Old Dec 5, 2005 | 02:56 PM
Frank89IROC's Avatar
Re: Help.. Whats This Part Called?
iT'S A PLASTIC PIECE, called "heater control valve". It controls the water flow to the heater core. When you turn on the AC, it cuts off the flow into the heater core, for maximun cooling into the passenger compartment.
Old Dec 5, 2005 | 03:20 PM
AC part# 74805 about $17.00 at least for my car (V8)
Old Dec 10, 2005 | 01:56 AM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Those plastic heater control valves weaken and break when they get old. They should be replaced before that happens.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
86White_T/A305
Aug 17, 2015 12:16 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
