temp sesor problem
Old Dec 27, 2005 | 07:38 PM
linkz761's Avatar
Car: '86 Trans Am
Engine: stout 350
Transmission: automatic
temp sesor problem
Just started up my car for the sencond time, and this time we were gonna let it run for like 20 mins. But half way through i noticed that the temp wasnt registering inside the car, and we turned it off just in time to stop it from over heating. So I was wondering what would cause this. The fan didnt come on either, so i was wondeirng if anyone could help me with this, i want to drive my car but i want it to be reliable and stuff. So someone please help me!
Old Dec 28, 2005 | 01:25 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
How do you know it was about to overheat if the temp gauge doesn't work?
As far as the temp gauge itself, make sure the sender in the driver side cylinder head is there and plugged in. Single green wire. If it is there an plugged in, try replacing the sender.
The temp gauge and the fan control are on 2 seperate circuits and have nothing to do with eachothers functionality aside from the fact that they both measure the temperature of the coolant.
Old Dec 28, 2005 | 01:43 AM
linkz761's Avatar
Car: '86 Trans Am
Engine: stout 350
overheat
Well, we figured out today that i crached the therm housing when i was putting it on (second one!) anyway, my dad wanted to run the car some more cuz he likes to hear it, lol, and he thought loosening the radiator cap would releive the pressure on the therm housing. I knew it was close to overheating cuz when i turned the car off a bit of antifreeze boiled out of the cap. Hope i didnt mess anything up to bad. Anyway, I replaced the fan switch with a Jet one so it would turn on sooner. But it may not be working. And i think i took out the temp sender thinking it was for something else that i didnt need anymore, cant remember what though. Thanks for the reply!
Old Dec 28, 2005 | 11:17 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
The system gets pressurized when you run an engine. It will always flow out the rad cap if you release the pressure. It wasn't overheating. If it were, you would have been blasted in the face by steam/coolant.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
GTAman
Sep 21, 2015 09:57 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
