Deflector ? for a 88 GTA
Old Jan 3, 2006 | 11:26 PM
WHITELX1's Avatar
I have a 88 GTA with a blown sbc, I am having a cooling problem with it. I have a electric water pump, a be cool radiator and a restictor plate for a thermostat. I have the deflector that wraps around the whole bumper. Now on my friends GTA he had a deflector that went up towards the radiator. Is this a oem item, and if so where can I purchase it. Any help here would help me out alot. Or if anyone has any other ideas that they can throw in here also. Thanks CHRIS
Old Jan 8, 2006 | 04:13 PM
WHITELX1's Avatar
can anyone help me out with this, please
Old Jan 18, 2006 | 07:47 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Sounds like you are talking about the plastic insert that goes behind the nose of the car and angles the air flow toward the radiator. This is an OEM item.
You could try your local dealership and see if they can order one. Your best bet is probably to check out a wrecking yard or or even eBay.
Also, quick question. Why the restrictor plate and not a thermostat?
http://www.stewartcomponents.com/tec...ech_Tips_3.htm
Old Jan 30, 2006 | 12:16 AM
Meinherr49's Avatar
Car: 1988 Pontiac Formula 350TPI HARDTOP
Engine: 04- 350 Crate Motor with Crane Cam
Axle/Gears: 10 Bolt Posi 3.73:1
Air Dam Reflector for TRANS AM 3RD Gen .
Is this what you are looking for ?
Attached Thumbnails Deflector ? for a 88 GTA-2-piece-air-dam
Old Jan 30, 2006 | 06:09 AM
WHITELX1's Avatar
I have that what it looks like I am missing is the baffles that go under the front bumper. Would that help with the cooling at all. Thanks
Old Jan 30, 2006 | 07:02 AM
Meinherr49's Avatar
Yes , it Directs incomming Air into the radiator . You can get a New one at several Parts places .
Old Jan 30, 2006 | 03:28 PM
WHITELX1's Avatar
Can you please help me out with the names to these places. Thanks in Advance
Old Jan 30, 2006 | 07:17 PM
Meinherr49's Avatar
Parts Vendors
www.hawksthirdgenparts.com
Ebay Store- Jennings Genuine GM Parts
Those are two that I can think of who sell air Dam Reflectors .
Hope that Helps ......
P.S . A Air Dam Reflector could be Found Cheap at a Local salvage Yard . And you only need part of it anyway . Think about it CHI Town.
Old Feb 2, 2006 | 02:33 PM
Car: Yes...
Re: Parts Vendors
What I think he needs are the insert panels that go up inside the nose of the car to close it off and direct the air flow into the radiator. Not the deflector or "blade" that mounts under the nose of the car.
F-body-fan
Jan 12, 2023 01:49 PM
sheachopper
Jul 31, 2019 11:27 AM
2012sergen11
Oct 13, 2015 07:38 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
