Fan switch missing!
Old Jan 11, 2006 | 09:04 PM
Digger's Avatar
Fan switch missing!
I bought an 86 Iroc with the single fan. The fan was wired directly to the fuse box. So I got checking around and replaced the wires going to the relay, and replaced the relay. The fan didnt come on automatically. So I got checking around and I found that there was no fan switch or wires between 6&8 cylinders. Is there a different location that they put these? All I can find is the A/C switch wires. Which leads me to my question.
Can I wire in my new fan switch inline with the A/C switch?
Digger
Old Jan 12, 2006 | 02:20 PM
conebowler's Avatar
Car: 1984 Z28 & 2001 Z28
Engine: ZZ4 &LS1
Transmission: A4 & M6
switchy
Hi, If I remember correctly the fan switch is in the intake manifold. Its a 1 wire with a black squeeze type connector. The switch in the head is for your temp gauge.
Old Jan 12, 2006 | 02:50 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Fan switch is the passenger side cylinder head.
CTS for the ECM is in the intake/water neck.
Temp sensor is in the driver side head.
Old Jan 13, 2006 | 10:16 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Old Jan 13, 2006 | 02:38 PM
conebowler's Avatar
Engine: ZZ4 &LS1
switch
well since he states its not there, perhaps it was moved? Or broken off??
My 84 has it in the t stat housing , my old 85 Iroc had it in the t stat housing? But my dual fan 89 had it in the pass head.
Digger, can you post pictures of your engine so we can help you find it? Hope its still pretty close to stock. A close up of right side, left side and frontal shot.
Sometimes its hard to see between the plug wires, especially if you have AC.
Old Jan 19, 2006 | 12:53 PM
Digger's Avatar
Does the fan switch go right to the relay or does it go through the computer first. Because my green and white wire was not spliced at all from the computer to the relay.
As for the switch being broken off, there is just a square 3/8 pipe plug in there. And the part that troubles me is that I took the wiring harness apart and I could not find the blue wire at all. Anyway Ill try to take some pics for you guys from the front, to , bottom, where ever.
Digger
Old Jan 21, 2006 | 07:36 PM
conebowler's Avatar
Engine: ZZ4 &LS1
yes pictures should help. also do you hav AC? Is there an engine driven fan and this is an auxillary type?
Fan is hard wired to relay meaning it doesn't run through the PCM. vin you can send pictures to my email....
Old Jan 22, 2006 | 09:26 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check the following link for the pass side switch (this one won't look like yours, but you'll see the correct location):
https://www.thirdgen.org/techbb2/sho...hreadid=309711
JamesC
Old Feb 15, 2006 | 08:02 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
My '86 doesn't have a fan switch, there is a plug in the pass head where the switch should be, the fan is controlled by the ecm, although the factory setting is a little high, imo.
I also bought a set of used '86 heads from a member here that also had the plug in one of them. I guessing that it is not uncommon for the 86's to not have a fan switch.
I installed a fan switch in the dvr side head where the gage sender should be, and moved the gage sender to the water neck. The only thing is, now the gage won't read 'till the t'stat opens!
eightsixseven
Dec 16, 2024 01:50 PM
The_Phoenix
Feb 4, 2016 07:10 AM
krisner89
Oct 10, 2015 06:03 AM
Ducati900ss
Sep 2, 2015 09:05 AM
TA8487
Aug 16, 2015 12:21 PM
