Think I Pulled Something loose
Old Jan 24, 2006 | 05:07 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Ok folks, I went out yesteday to see if i could replace the burnt out bulbs in my car behind the AC/HEAT controls, and I dont know what I did, but when i uncrewed it from its place I couldnt get around it to find out where the bulbs were, so I decided not to mess with it anymore, and now, after everything is screwed back in, the fan wont work anymore on any setting.
I think I pulled something loose, the controls are all push button, on an 87 GTA, i dont know what to do, someone plz give me some help on how to get my fan working again, the HIGH setting didnt work before this, but now none of them do.
help
Old Jan 24, 2006 | 05:49 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
probably disconnected the connectors, since you said yours is all pushbutton that means the only thing back there are electrical connectors.
Old Jan 25, 2006 | 08:01 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
alright then, do I need to take it to a pontiac dealer or what?
I dont trust a local average joe shop to mess with it.
Old Jan 25, 2006 | 08:03 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Just pull it out again, push all the connectors in tight, then try it.
Old Jan 26, 2006 | 05:14 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
as i said, I dont have enough room to pull it out, it comes out just a little, but no enough to get behind it
Old Jan 26, 2006 | 07:29 PM
meridius's Avatar
pull the radio out, should give you enough room to reach up around and see what cae unplugged
F-body driver
Mar 6, 2023 11:44 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
lakeffect2
Sep 7, 2015 03:52 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
middian
Sep 5, 2015 01:42 AM
