removing A/C from a v-belt set-up
Old Feb 2, 2006 | 08:17 PM
Trah84Z's Avatar
Car: 1984 Z28 ~Brown Horse~
Engine: 305 V8
Axle/Gears: 3.23...i dunno...
i've searched topics but i still feel uncomfortable so i thought i would ask for specific instructions. my first question is do i remove the pully that controls the A/C. (i'm assuming it is the one on the drivers side.) and i'm also in Cali so the smog laws are pretty strict. do i just remove all of the hoses going to/from the A/C canister? if anybody has any specific instructions on what pieces to remove that would be awesome...
Old Feb 3, 2006 | 04:17 PM
JDubya18's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 LB9
Theres alot of threads that cover this
Heres a useful one, only difference is that its for a serpentine setup but its still the same. You will remove the belt for the AC.
https://www.thirdgen.org/techbb2/sho...ight=ac+delete
PS remember to get the system evacuated before you attempt this.
Old Feb 3, 2006 | 06:23 PM
Trah84Z's Avatar
Engine: 305 V8
i have read that thread and it has answered a lot of questions. but, since i run a V belt set-up, do i remove that whole pully set-up? since i don't need it like i would a delete pully in a serp. set-up right? and where do i go to get it evacuated and how much should it cost?
Old Feb 4, 2006 | 02:22 AM
JDubya18's Avatar
Engine: 305 LB9
Yeah you take the whole compressor out which has the pulley on it, no need for any kind of delete pulleys. When I got my system evacuated it was like $20, any auto shop should be able to evacuate it.
Old Dec 31, 2006 | 03:55 AM
jcisthechamp05's Avatar
Car: 1987 IROC-Z
sorry to pull up an old thread, but i was getting ready to pull the a/c out of my car.....but I'm not really sure what you mean by evacuating the system, I'm thinking removing the coolent(r-12 its called I think) form the system?
Thanks John
Old Dec 31, 2006 | 04:44 AM
Car: 1987 IROC-Z
n/m I did more searches and found it. It is removing all the freon out of the system btw.
Old Dec 31, 2006 | 09:32 AM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
The chaces of any refridgerant being in the system is slim. Unlike home units, the seals in car systems dry out and leak. Press in port amd see if anything comes out.
All a/c comp have equipment needed, just offer couple of bucks on the side.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
64goatman
Sep 9, 2015 01:09 PM
Ironhead38
Sep 7, 2015 02:26 PM
85Special
Sep 3, 2015 04:21 PM
