Im looking at installing a aluminum radiator in my 89 formula. The motor is mostly stock with some add ons (cold air induction kit, SLP air foil, ported runners and plenum ect). I want to find a direct fit one that im not going to have to modify anything in order to get it to fit, such as the radiator shroud becuase i have the dual fan assembly. I looked at summit and they do sell one however i noticed that some of the things dont look 100% correct like my orginal one such as the petcock(drain plug), mines on the passenger side and the summit one is on the driver. Anyone have any info on this?...or have a aluminum one that they've installed with no problems? I already looked into that northern company, there radiator is the same thing...just doesnt look 100% right.
i have a new one on mine from auto zone. the sides feel like plastic and the actual fins are aluminum. ran me about 100 bucks.
thats not bad at all....did you notice any difference in temp at all? Anyway u can snap a pic of what it looks like? Thanks man...nice looking ride too.....you dont see to many nice condition formulas around anymore
thanx for the compliment
ill try and snap a pic later today at work. i think it does run a lil cooler. and thats a good thing b/c now i have an A/C condenser mounted in front of it and my old aftermarket tranny cooler.
ill try and snap a pic later today at work. i think it does run a lil cooler. and thats a good thing b/c now i have an A/C condenser mounted in front of it and my old aftermarket tranny cooler.Supreme Member
I installed a BeCool 2 row (2 very wide tubes) rad in my 82Z. I'm currently using dual fans. Only things I had to do were; move the lower support rubber grommets over abt an inch or so and install a upper shroud extender plate (which was included with the rad).
Everything else lined up.
I've had the car since 84 and it has always run hot (+220*). Tried a 3 core copper aftermarket rad and a couple of cheap 2 core allum rads. Tried heavy duty belt driven clutch fans, direct drive flex fans, elec booster fans, upgraded water pumps, modified air dams, etc. Nothing seemed to help.
The BeCool rad made a huge difference. I've had it over a year driving in Texas heat, stuck in traffic, a/c running; I haven't went over 200 degs yet.
Got mine on ebay for $300. Best $300 I ever spent!!
only thing with the BeCool radiator's is I've read alot of people having many problems with them. It almost seems as though BeCool is a hit or miss. I dont have any experience, just relaying what I read.
What about SUmmit? I have been looking at the Summit brand replacement, all aluminum, and it says direct fit??? Anybody have any luck?
Quote:
Yea im with ya there man, thats the one im looking at getting, hope it fits!Originally Posted by 5.7iroc-02ws6
What about SUmmit? I have been looking at the Summit brand replacement, all aluminum, and it says direct fit??? Anybody have any luck? Buddy
close
- Join DateMay 2001
- LocationKars, Ontario, Canada
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car'87 FIREGOOSE!!!!
- Liked:120 Times in 103 Posts
Quote:
Wow. They're a high $ radiator, some say one of the best out there - you get what you pay for. To here they have problems is not good. What kind of problems are people having? Are they under warranty? I would hope so, for that kind of cash I'dd expect reliable service for years.Originally Posted by unklechuckles19
only thing with the BeCool radiator's is I've read alot of people having many problems with them. It almost seems as though BeCool is a hit or miss. I dont have any experience, just relaying what I read. Supreme Member
The Griffin 31"x19" is inexpensive and fits without modificatin in both Camaros and Firebirds.
Does any one have pics of the 31x19 griffin rad installed?
I don't think I have any pics - it 'just' fits width wise in my car and sits on a little bit of an angle vertically.
I got a griffin from summit. Its a direct replacememnt but is not cheap. a search under Firebird will not show it. However, it comes up under Camero.
The part # is: GRI-6-282AE-BAX
I spoke with Griffin and they said its for both cars. Mines sitting in the box waiting for the install
No, the universal one is only a couple hundred bucks;
From Summit:
GRI-1-25272-XS $213.69
From Summit:
From Summit:
I think he is looking for a direct replacement. Does this one have the built in tranny cooler, heater hose fitting, and over flow tank fitting.
There is no image at summit. The one i got is a direct replacement. However it is pricey
Buddy
close
- Join DateMay 2001
I'dd still like to know about the problems people are having with the Be Cool rads.
And I know there is a small cost variance, but which considered is the best rad out there, there are a few,
Be Cool
Griffin
Howe
Rodney Red
Mark or Mike Davis - something like that I think
That's just naming a few. Who's top dog??????????
Be Cool
Griffin
Howe
Rodney Red
lol....looks like in not the only one having this problem then. So does or is anyone using the summit brand rad? If so was there a problem installing it or did it not have a fitting that it was sapost to?..cause thats the one im looking at purchasing.
Got the Modine from Napa... AAA discount too.. direct fit.. works for me..
About 20 lbs lighter than the old one i took out... but its got plastic tanks, not sure if thats what you are looking for, but if you want easy install, its nice.
yeah im tryin to find a all aluminum one. At this point im bout to say screw it and buy the griffin one....now if i can only find someplace that has one in stock. Summit is out until april 10th. So far the only place that seems to have them is hawksthirdgen...and they want to most..$469.00!....i know that becool is more...but im gonna try and find that lower than that.....to me thats just touch much
If I could have paid $500 for a radiator, I'd be happy, haha
Have you looked into Northern?
https://www.thirdgen.org/forums/show...hreadid=258752
While I haven't personally used them, Northern seems to get several good nods.
I would like to know about the one from summit as well. They just started to advertise them in the new catolgue. It does say direct fit and it less then 250.00.
500.00 to 600.00 for a becool is crazy. And from what ive read its not a direct fit either.
Has anyone tried the one from summit?
I have heard that this radiator is built for summit by "Northern"
I knew I saw something about this.
Try this: https://www.thirdgen.org/techbb2/sho...hreadid=258752
Hope this helps
Hope this helps
I am sorry but for the bang for the buck you guys need to get a giffin rad, It looks factory. But i had to make a custom upper shrowd. If you are going to buy a radiator and you are kinda handy go get a giffin, got mine for 225.00 thanks
I put a tall/wide truck radiator in mines. I had to drill hole at the top were the brackets go. It kind of leans back but works fine...Have anyone did this?
