heat/AC
Old Mar 13, 2006 | 09:07 AM
justlearning's Avatar
Car: 91 camaro 305 tbi
Engine: 305 tbi l03
heat/AC
okay when i got in the ride this morning i had no air blowing from the vents on heat or ac...also no defrost. i had no water in the floor board so i dont think its a heater coil and cause there was no air blowing. checked the heat/ac fuse and it looks fine. im thinking that its my blower motor any other ideas. if it is the part is cheap but how hard is it to change and whats a ruff idea on what has to be done to swap it i dont have to discharge the cooling system do i?? please help its supposed to be cold tomorrow and i will need the defrost to see. thanks
john
Old Mar 14, 2006 | 11:06 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Check the power and ground wires/connections on the blower fan. They are known for corroding.
The fan is located under the hood, on the firewall, just behind the pass side strut tower.
Don't need to drain coolant to replace blower motor.
dboersma69
Jul 16, 2015 09:18 AM
Barlow8869
Apr 12, 2013 12:02 PM
Warrior
Oct 28, 2009 05:07 PM
Marksp
Aug 26, 2006 12:33 PM
Maul
May 12, 2002 09:10 PM
