Cooling System Wont Hold Water
Old Mar 19, 2006 | 02:16 PM
unklechuckles19's Avatar
Car: 1987 Z-28
Engine: 355
Axle/Gears: 10 Bolt/3.23 peg leg :(
I've just started noticing this, and it hasnt done it before. All stock pieces, rad., thermostat, waterpump. It seems like the coolant just evaporates, and disappears. Nothing is leaking, I've been under the car a few times since I've noticed this, seen nothing. There are no puddles under the car after its parked, and it seems to run at normal tempature. Everytime I fill up the tank, it disappears, where is all this coolant going?
Old Mar 19, 2006 | 07:44 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
"follow That Cloud!"
<CENTER><B>
Another it could be leaving is thru the exhaust pipe.</FONT>
</B><FONT COLOR=F3399><H5>
“If people drove any slower they’d be going backwards.”</FONT>
<FONT COLOR=FF66FF>NINÅ</H5></FONT>
<P>
<TABLE BORDER=9 CELLPADDING=8>
<TD BGCOLOR=black>
<B><H3><CENTER>REFUSE
TO
LOSE<p></TABLE></CENTER>
Old Mar 19, 2006 | 10:17 PM
Car: 1987 Z-28
Engine: 355
where would it be leaking into the exhaust from, the water jackets in the heads?
Old Mar 20, 2006 | 10:09 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
It wouldn't be leaking into the exhaust, it would be getting burned off in a combustion chamber. Pull all 8 spark plugs and see if any look cleaner than the rest. Check the oil, too.
Head gasket, cylinder wall, cylinder head, intake to cylinder head.
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
lakeffect2
Aug 23, 2015 08:44 AM
sreZ28
Aug 14, 2015 07:48 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
