New location for fan switch
Old Feb 22, 2006 | 08:56 AM
PurpleHaze92's Avatar
Car: 1992 rs
Axle/Gears: ones that turn
Hey eveyone, I obviously have a question. I have a '92 rs that has been converted from TBI to TPI. I have everything hooked up with the exception of the fan switch. I know where it is supposed to go but, the block is an '86 and there is a plug where the switch is supposed to go. I know just take the plug out! Right? Nope! Not my luck, the plug stripped! . Anyone know an alternate place to install the switch? Any help would be greatly appreciated, as it is starting to warm up here in Texas and would like to finally get this car on the road! Thanks for the help.
Will
Old Feb 22, 2006 | 09:57 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
The normal place for the fan switch is in the cylinder head on the passenger side... Is this the plug that was stripped out??
Old Feb 22, 2006 | 09:59 AM
Car: 1992 rs
Yes, it is.
Old Feb 28, 2006 | 10:09 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I don't like the stock fan switch - never got one to work. I got a controller for the fan with the temp probe that sticks through the blades on the radiator - well worth it in my book to not have to fool with that damn switch on the head.
Old Mar 10, 2006 | 10:03 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Camaronewbie how accurate/effective do you find the fan controller your'e using with the radiator temp probe?Do you have the probe inserted thru the fins or set parallel to the tubes?I'm assuming you have it on the upper right as near as possible to the upper hose inlet
Old Mar 11, 2006 | 04:27 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
When I had them installed into my radiator, we removed fins and installed them (the temp probes) between the horizontal tubes. Over time (bumps, rattles, shakes, whatever) I've seen probes work their way out - just a heads up. With the airflow over the radiator and all, I'm personally not a fan of using it as the location for a sensor. Besides, this really only works for the 1/8" NPT probes, not the big bulky stockers.
I have my primary sensor in my waterneck but I probably don't count.
With a factory-sized sensor, a head would be the best bet. It can thread into either side.
On a side note, have you tried drilling out the plug?
Old Mar 11, 2006 | 08:40 AM
Car: 1992 rs
no I haven't tried to drill it. The engine is in the car.
Old Mar 12, 2006 | 03:05 AM
r62mcmahon's Avatar
Car: 1989 IROC
Axle/Gears: BORG WARNER /3:70
i run both fans on separate rocker switches
Old Mar 12, 2006 | 10:05 AM
Car: 1992 rs
Do you have any schematics for this?
Old Mar 14, 2006 | 05:05 PM
r62mcmahon's Avatar
Car: 1989 IROC
i just spliced into the brown wire at the fan relay to a rocker, then to constant batt. source. i did the constant power so i can have fans running w/ ing. off so car will cool down between rounds
Old Mar 14, 2006 | 05:36 PM
Car: 1992 RS
Engine: Carbed 350
coolram62 -
On my 1992 I have the probe stuck right through the radiator, between the fins, on the pass side. Had to do it on the pass side, since there wasn't enough wire on the probe to run it all the way across, and I chose to mount the controller on the pass side. It also has a cap that squeezes over the end, preventing it from coming back out - as tight as it is, I don't think it'll be going anywhere soon. It seems to work great, it even hooks into the wiring for the A/C to run the fan always when A/C is on.
On my 1990 Camaro, I've been through 4 fan switches, including an expensive aftermarket job, and none have worked well - I finally gave up and I just leave the A/C switch on always, which runs the fan always - my A/C is empty, so the compressor doesn't run anyways.
Old Mar 19, 2006 | 10:14 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
PurpleHaze92, turn the key on & ground the wire that goes to the fan temp switch to see if the fan comes on, if it does then just run that wire inside the car & hook it up to a switch. them run the other side of the switch to a good ground.
camaronewbie, it sounds like you were running power to the fans through those switches. they needed to be setup to control the fan relays.
Old Mar 20, 2006 | 10:25 AM
Car: 1992 rs
DENN_SHAH,
I'll check that out asap, if that works im gonna owe you not one but two beers next time im in Houston, one for this and one for the alt you helped me on! T
hanks in advanced.
-Will
eightsixseven
Dec 16, 2024 01:50 PM
krisner89
Oct 10, 2015 06:03 AM
Ducati900ss
Sep 2, 2015 09:05 AM
TA8487
Aug 16, 2015 12:21 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
