Can I replace just the clutch on the a/c compressor?
Old Apr 5, 2006 | 12:23 AM
BigPile2's Avatar
Car: 1991 Firebird
Engine: 305 TBI
HI,
The clutch on my a/c compressor is starting to freeze up. Is there a way to replace or repair the clutch or bearings without having to replace the entire ac compressor?
Thank you in advance,
Rob
Old Apr 5, 2006 | 05:45 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
You can rebuild the A/C clutch by replacing the bearings or you can purchase a clutch assembly(these will come with a 1 yr -sometimes lifetime- warranty).It's pulled off the compressor similar to the alternator and pwr steering pulleys.
Old Apr 5, 2006 | 10:46 AM
BigPile2's Avatar
Car: 1991 Firebird
Engine: 305 TBI
How do I remove the ac clutch?
I see there is one bolt in the center of the a/c clutch, but when I put a socket on it, the whole inner part turns....also, is it lefty loosey as normal??
Thanks, Rob
TheExaminer
Aug 25, 2015 07:34 PM
Bryan F
Aug 18, 2015 02:28 PM
rsrmoore
Aug 7, 2015 08:44 PM
Thaney9
Aug 7, 2015 08:25 PM
