Help: coolant to intake manifold question
Old Apr 11, 2006 | 06:57 PM
1goodcuppa
Guest
Posts: n/a
Chevy Camaro, 2.8L V6
My car was leaking coolant from the hoses that connect on the bottom of the throttle body to a valve stem on the engine. To me, it looks like the coolant just goes through the throttle body and comes back out (my friend thinks it's to warm up the throttle body?), but the Chevy mechanic said they go to the aluminum intake manifold to cool it off.
We changed the hoses, but it is still leaking coolant from somewhere around the throttle body/manifold. I'm going to take it to the shop tomorrow to find out exactly where it's leaking from.
My question is would it be okay if we just bypassed the intake manifold cooling (if that's what it is) by connecting the bottom pipes? Will it melt the manifold?
PS This is my first post. Hi, to everyone.
Old Apr 11, 2006 | 08:00 PM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
I have a V8 TPI and I did the coolant bypass. The purpose is for the coolant to give a little extra heat to the throttle blades so they don't freeze or stick in colder climates. I ran the hose from that "T" thing, that has the hose coming from the firewall, directly into the intake manifold. It will not hurt your manifold at all, may even help the temperature of the incoming air too. Check the Tech section, I got a set of instructions from there and it works great.
I do think it's funny that your mechanic said that it would go thru the intake manifold to cool it off; may want another mechanic.
Good luck..Eric
Old Apr 11, 2006 | 08:15 PM
1goodcuppa
Guest
Posts: n/a
If I just unhook the tubes from the throttle body and connect them, and just leave the holes on the throttle body open, would that be okay?
Like the "quick" method described here? https://www.thirdgen.org/coolantbypass
Old Apr 11, 2006 | 09:13 PM
1goodcuppa
Guest
Posts: n/a
Where I can get that copper/brass patch coupling from? I called the parts stores and looked in my books and I can't find anything like it.
I need one that is shaped like a U, preferably.
Old Apr 12, 2006 | 12:02 AM
redbird8628's Avatar
Car: 1986 Firebird
Engine: 3.4 outa 95' bird
Axle/Gears: 3.42 open rear
ask a parts store if you can browse their hose section, just look for a U shaped hose, and dont bother with the throttle body, its working for me
Old Apr 12, 2006 | 12:39 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
if you have a v6 it is different from the picture in the article. just go buy a length of rubber coolant hose and make a big loop over the thorottle body. and yes it is ok to leave the throttlebody holes open.
and yeah, new mechanic time. "well, all the friction from the air gets that sucker pretty hot" if he tells you to replace your muffler bearings every thirty thousand miles call the cops
Old Apr 12, 2006 | 03:38 PM
Car: 1986 Firebird
just get a small radius U shaped hose, using the length of heater hose going around the throttle body looks hideous
Old Apr 21, 2006 | 05:19 PM
Morit's Avatar
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
Can you please see my question at https://www.thirdgen.org/forums/tpi/...ml#post2850347 ?
Sorry for double posting, but it is something that might help me a bit at 1/4 racing next week
ASE doc
Alternative Port EFI Intakes
Jan 12, 2020 11:35 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
theurge
Aug 21, 2015 12:46 PM
Jake_92RS
Aug 11, 2015 10:39 AM
