T/B heater bypass?
Old Dec 7, 2005 | 09:45 PM
Syn's Avatar
Syn
Car: 1989 Formula Ws6
Engine: 305 tpi
Transmission: 5speed
T/B heater bypass?
I have done this on my older v6 cavalier, i looked at my 89 305 tpi, and i see a coolant hose goes in and out of the t/b most likely as a heater for it. can this be bypassed? theres little gains in doing it i hear.
thanks guys
Old Dec 7, 2005 | 10:19 PM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
Yes, it can. Theres a kit floating around for $8, or you can do it yourself.
Old Dec 7, 2005 | 11:06 PM
Syn's Avatar
Syn
Engine: 305 tpi
yah i ment can anyone tell me how to do it so i don't mess anything up?
Old Dec 7, 2005 | 11:13 PM
superGMman's Avatar
Engine: 22R-E
Axle/Gears: 4:??
Here, tell me if this doesn't work
http://www.geocities.com/MotorCity/Track/9558/tbbypass.html
Old Dec 8, 2005 | 12:02 AM
Syn's Avatar
Syn
Engine: 305 tpi
yah i had to maually type it in but it worked thanks alot
Old Dec 8, 2005 | 09:28 AM
superGMman's Avatar
Engine: 22R-E
Axle/Gears: 4:??
no prob
Old Dec 8, 2005 | 07:43 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
yep any heat removed from the motors air intake will help. Maybe not much but it should on those hot days.
Old Apr 21, 2006 | 05:17 PM
Morit's Avatar
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
I got a little question. Since bypassing will help a bit, becouse hot coolant will not wamr throttle.. Will cooling it help?
I mean, something like giving some system with some cold fluid flowing through where orginal cooling fluid used to go in TB..
What do you think?
Old Apr 21, 2006 | 05:47 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Ever heard of Icing the intake during drag passes
Old Apr 21, 2006 | 06:49 PM
Tims 88gt's Avatar
Car: Mustang
Engine: 302
Transmission: 5spd
Axle/Gears: 8.8 with 3.73
my stang is the same way. i just bypased it.
Old Apr 22, 2006 | 02:39 AM
Morit's Avatar
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
I know probably noone has done it. Its just an idea.
$750 L98
Feb 1, 2025 02:25 PM
Formula8r89
Sep 22, 2015 04:24 PM
