Temperature Gauge Installation?
Old Apr 13, 2006 | 06:50 PM
km7152's Avatar
Car: 1991 Camaro Rs
Just added 3 gauges, volts, oil and water temp. Wheres there a spot on the block where i can screw the sensor in that leads to the gauge? If possible to keep the stock one working? I just needed a gauge to fill in a hole, until I find the time/money to hook up a different gauge.
Old Apr 19, 2006 | 05:18 PM
92'Sleeper's Avatar
Car: 92' B4C Camaro
Transmission: G-Force T5
Below the Trottle Body on the passenger side of the Intake you will see a pipe plug there. That is a good place.
Old Apr 19, 2006 | 09:03 PM
km7152's Avatar
Car: 1991 Camaro Rs
Ok i noticed that plug, i had no doubt a gauge could be mounted there but wasnt sure what it would be reading as far as water, oil, or even jsut air. Thanks man.
Any chances youd know of an extra place to mount an oil pressure? Gauges have been a huge pain in the *** so far
Old Apr 20, 2006 | 11:26 PM
km7152's Avatar
Car: 1991 Camaro Rs
I have the adapters to hook up to the smaller plug, on the driver side of the intake, but a few inches away on the passenger side is an even bigger one. What are each of these, or are they both just different coolant taps?
Frozer!!!
Jan 19, 2024 04:55 PM
rocn7roc
Sep 21, 2021 02:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
