Water pump installation
Old Apr 19, 2006 | 04:30 PM
Chr1s46536's Avatar
Car: 91 RS
Engine: 305 TBI
I am going to have to replace my water pump sometime in the very near future and i was wondering if i would be worth it to do it myself. So far using one of those hayes books ive done my alternator and my starter but a friend of mine who works at pepboys said a water pump would be harder.(If i sound like i dont know anything about fixing cars its because i dont). Will it be worth it $ wise to do it myself or pay some extra cash to get it done correctly and quickley.
Old Apr 19, 2006 | 05:14 PM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
it isn't very hard to do. if you've replaced the alt. and starter by yourself, you can propably do the pump too. just remove the belt, the hose at the pump and the 4 screws from it.
nebu.
Old Apr 19, 2006 | 05:47 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
drain the coolant first, take off the belt. disconnect the hose going into the inlet on the top of the water pump. unbolt 2 bolts on each side, 9 1/6 i believe, and you may have to pry it off.
Old Apr 19, 2006 | 07:32 PM
purg3d's Avatar
Car: '92 RS
I'd dare say it's easier to replace the waterpump than to replace spark plugs on these cars.
As was said above, drain the radiator, take off the belt and bam, 4 bolts and you're good to go.
Might be a good idea to loosen the bolts on the pully a tad with the belt still on, as I've heard they can be difficult to remove, but I didn't have that problem.
If it's a serpentine setup, shouldn't be a problem. Just make sure the waterpump is correct for your application (long neck/short neck, reverse/standard rotation) and keep in mind the lower hose might still coolant inside.
Old Apr 19, 2006 | 08:10 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
It's easier than the starter - no crawling, just bending!
Old May 1, 2006 | 08:17 PM
rapidfiremeyer's Avatar
Do you have to remove the radiator to get the water pump out??
Old May 1, 2006 | 08:20 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
No.
Old May 1, 2006 | 08:52 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
dont pay to have something this minor done
trust me
its not hard to do, you cant get much easier waterpump job than a sbc one
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
