Problem with fan relay
Car: 92 camaro vert.
Engine: 305 TBI
Axle/Gears: 4th gen with 3:42
I know I've seen a couple of threads about this but I never got a straight answer. Its off of a 92 camaro, single fan, TBI
Engine: 305 TBI
no its all stock wiring. The wire going to the battery is good. I havn't checked the ground. Don't know where it is really.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
That's not the relay burning up - it's the wirepack (the relay has the male ends, the wirepack has the female ends, and that's what's burnt in your pics). If it's blowing relays, it's because the wirepack is toast. Replacement wirepacks were available at GM dealer (as os 18 months ago) - I had to replace mine - did the same thing - but replaced and it's all good.
eightsixseven
Dec 16, 2024 01:50 PM
db057
Aug 11, 2015 10:11 PM
